Modulus of Elasticity vs Temperature
I would like to find information (graph etc.) on how the Modulus of Elasticity of steel is affected by temperature.  The material that I am particularly interested in is 2.25Cr 1Mo?
RE: Modulus of Elasticity vs Temperature
See ASME IID table TM-1
The alloy doesn't matter.  The modulus is a function of the matrix.
For this grade it is almost a straight line from 31Msi at romm temp to 22Msi at 1300F.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
