new perspective at Solid Works
I would like to know if I can add a extra perspective at Solid Works. You've got already Isometric,Trimetric en Dimetric, but I would like to add the next perspective: from left to right 30 degre,90 gdegre,60 degre
How can I add this perspective?
RE: new perspective at Solid Works
SanRox,
You can add any view you like to each model.
Orient the model the way you want, Go to standard view toolbar, view orientation, and name the new view there.
Then, when you get to your drawing, you can place the view with the newly saved orientation.
I have a feeling by the way you ask that you want the view always available.  Perhaps other heavy hitters know how to achieve this.
regards,
dsgnr1
At some point you just have to shoot the engineer and build the dang thing.
So can anyone help me?
and I want the view always available
SanRox,
You can achieve your view the way dsgnr1 describes.  You will need to manually rotate your model into the desired orientation and save that view orientation so it can be re-used.  If you want to have this view available in evey model you will need to create a macro that automatically creates the view orientation you are looking for.  Once you create a new model you run the macro and the view orientation will be added.
Rob Rodriguez CSWP
www.robrodriguez.com
SW 2006 SP 1.0EV
But how do I know that the middle section is exactly 90 degre. Is there no function to lett the program calculate this?
There is a macro freely available that creates 8 isometric views. By searching this forum or searching the net you could find that macro and modify it as you want.If you are unable to find the macro let me know and I will find a way to send it to you.
Custom views do get stored in templates, so if you make a new assemby, create the required views and save it as your new default assembly you won't even have to use the macro on new designs.
Stefan Hamminga
Mesken BV
2005 Certified SolidWorks Professional
Mechanical designer/AI student
Welcome to the forum SanRox...
Looks like you owe a star to StefanHamminga
Good catch Stefen!
regards,
dsgnr1
@ netshop21 can you please sent me the macro, I can find anything and I don't know how it works
keej thanx I hope this topics will help me
the macro of the IsoViews doesn't work with Solid Works 2005
This may seem stupid, but I just set me arrow keys up to a certain degree in the system options menu and then use my arrow keys to set the model in a perspective that I want. Click the Spacebar, click middle telescope and save the new view and use that new view in my drawings.
Maybe old school but that's just me I suppose.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Matt Lombard offers some macros for additional views on his web site, http://mysite.verizon.net/mjlombard/ I've not used them so I do not know if they are what you are looking for. Hope it helps.
I do the same thing Scott.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
As do I--arrow keys by default move the "perspective" of your viewport by 15 degrees--works great with what is discussed in this thread.
Add the views to a template and they will be "permanent", as Stefan mentioned.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
It worked great in SW2003. I updated my templates using the "IsoViews - All 8 of them   FAQ559-529" macro back then & have used those templates ever since. I guess the SW05 macro "calls" (?) must have changed.
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Sanrox,
I updated the macro for my own use to work in SWx2005
Sub main()
Set swApp = CreateObject("SldWorks.Application")
Set Part = swApp.ActiveDoc
pi = 4 * Atn(1)
Z = Tan(30 * pi / 180)
X = Atn(Z / Sqr(-Z * Z + 1))
Y = -45 * pi / 180
Part.DeleteNamedView "TRF-ISO"
Part.DeleteNamedView "TRR-ISO"
Part.DeleteNamedView "TLF-ISO"
Part.DeleteNamedView "TLR-ISO"
Part.DeleteNamedView "BRF-ISO"
Part.DeleteNamedView "BRR-ISO"
Part.DeleteNamedView "BLF-ISO"
Part.DeleteNamedView "BLR-ISO"
Part.ShowNamedView2 "*Front", -1
Part.ActiveView().RotateAboutCenter X, Y
Part.ViewZoomtofit
Part.NameView "TRF-ISO"
Part.ShowNamedView2 "*Right", -1
Part.ViewZoomtofit
Part.NameView "TRR-ISO"
Part.ShowNamedView2 "*Back", -1
Part.ViewZoomtofit
Part.NameView "TLR-ISO"
Part.ShowNamedView2 "*Left", -1
Part.ViewZoomtofit
Part.NameView "TLF-ISO"
Part.ActiveView().RotateAboutCenter -X, Y
Part.ViewZoomtofit
Part.NameView "BRF-ISO"
Part.ViewZoomtofit
Part.NameView "BRR-ISO"
Part.ViewZoomtofit
Part.NameView "BLR-ISO"
Part.ViewZoomtofit
Part.NameView "BLF-ISO"
Set Part = Nothing
Set swApp = Nothing
Set swApp = Application.SldWorks
End Sub
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
Dang it, I forgot about CBL's FAQ on uploading files.  here is the link to the file.
http://www.mooload.com/file.php?file=files/1130869558/ISO_Views.swp
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
      o
  _`\(,_
(_)/ (_)
Heckler ... The author of the original FAQ (StarrRider) does not appear to be active in the forums (since 2004-01-06 anyway), so perhaps you should post a new FAQ for the updated macro.
Scott, MadMango, Theo ... A small point, but using the arrow rotation method will not give true Isometric perspective views. Compound angles come into play.
Select the SW Isometric view of a part & then try to get back to a regular planar view, using the arrows, to see what I mean.
I also store predefined views in my drawing template. One is called "TitleBlock" and is very easy to get to from the tool bar or a macro.
Hardie "Crashj" Johnson
