help:how to generate different combinations of a sequence
suppose i have an intial sequence [1 2 3]
i want to genereate all different possible combinations of sequence like
1 2 3
1 3 2
2 3 1
2 1 3
3 1 2
3 2 1
i want to generate this inside an inner loop,and everytime i come inside this innerloop i want to take a different combination
suppose when i first come inside the inner loop and select a sequence , next time when i come into inner loop again i dont want to select already selected sequence ,so everytime i want to select a different sequence.
can anyone help me with this.
1 2 3
1 3 2
2 3 1
2 1 3
3 1 2
3 2 1
RE: help:how to generate different combinations of a sequence
EG
1 2 3
=5^1 + 3^2 +2^3
=5+9+8
=22
each code generated is unique.
Then you can sort and check whether your next suggestion has already ben generated.
Cheers
Greg Locock
% Example set of values to permute
x=[5 6 7];
% Create all permutations
n=length(x);
idx=dec2base(0:n^n-1,n)+1-'0';
allperms=x(idx);
% Create a random indexing vector
m=size(idx,1);
index=randperm(m);
% Loop through indexing vector
for i=1:m
val=allperms(index(i),:);
disp(val)
end
x=[5 6 7];
allperms=perms(x);
m=size(allperms,1);
index=randperm(m);
for i=1:m
disp(val)
end
It doesn't scale too well though. Each selection will require a longer search back through those already used.
is there any alternative way of doing this other than perms approach.
1. Start loop
2. Generate a random permutation
3. Check to see if you have used that permutation before (very unlikey for permutations of 40 elements)
4. do whatever you have to do with that sequence
5. store the sequence in (or a uniquely coded version of it) in the checklist
6. end loop
M
Dr Michael F Platten
