All Around Symbol
All Around Symbol
I know there is an all around symbol for welds is there a symbol that I can use to specify that a fillet follows a complex edge all around the part?
RE: All Around Symbol
ASME Y14.5M does not yet recognize the "all around symbol" for a requirement that completes a closed loop. I have used it, however, to call out paints, finishes, and other requirements and the manufacturers have questioned its meaning.
When you say "fillet" do you mean a fillet weld?
Tunalover
I think that Bert13 means radiused edge when he says fillet.
What version of Y14.5 are you using that does not recognize the all around symbol? 1994 DOES.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
I was aware that the all around symbol applies to tolerances however the spec does not say it can be used for any other requirement.
Tunalover
I have seen a spec for it, I will look it up.
Chris
FAQ559-1100
FAQ559-716
I believe that if your drawing is prepared in accordance with A.S.M.E. Y14.5 1994, you certainly can use the all around symbol. Not sure if you got the message clearly.
I concur with ringman. We're pulling hairs here.
Tunalover
Jim Sykes, P.Eng, GDTP-S
Profile Services
CAD-Documentation-GD&T-Product Development
