Disolvable Tool Mandrel ??
We need to make a tool that has a very small opening when
finished, it needs to be made over a male mandrel.
I'd like to know if anyone has played with Wax or Casting Metals to acheive this ? Maybe Sand with a expandable bladder ?
We have to be able to remove the mandrel after the part is cured.
Any suggestions ?
Thanks !
Any suggestions ?
Thanks !
RE: Disolvable Tool Mandrel ??
google "soluble tooling" and there are 42000 hits.
good luck
Composites and Airplanes - what was I thinking?
There are gremlins in the autoclave!
another way I do it, first a waxed balsa plug, then a thin layer of glass and epoxy, when split open this shell, take the wood out, glue it back together, and laminate over this shell.
contact me if you want to talk more about this, I don“t check eng tips too often.
ht
