Problem with legend
Problem with legend
Problem with legend
I have a for loop which opens different ascii-files, does some calculations on them and the plots one column against another one from each file, and it does this for the files with numbers ifile to nfile. So I get 1 figure with various plots. Now I want to add a legend with the plotted lines, which just showes the numbers of the files.
This is part of my code:
infile='ascii';
ifile=1;
nfile=4;
k=1;
for icount=ifile:nfile,
    mx(k)=num2str(ifile);
    mx_2=mx'
    k=k+1;
***here are some calculations and defenition of x_value and y_value***
    hold all
    plot(x_value,y_value)
    ifile=ifile+1;
    legend(mx_2);
    hold off
end
So I want to use the vector mx_2 as the legend. If nfile is 4, then I plot 4 lines in one figure, and mx_2 is a vertical vector of 4 strings. However, I do get the following error. WHAT AM I DOING WRONG???
??? Error using ==> strcmp
The number of rows of the string matrix must
match the number of elements in the cell.
Error in ==> legend at 153
elseif (narg==1 && ischar(varargin{1}) && ...
RE: Problem with legend
buildString = int2str( ifile )
for...
eval( [ 'lengend( ', buildString, ')' ] );
buildString = [ buildString, ', ', int2str( icount ) ];
end
Hm, with that code I'm getting an error which I've seen before:
??? Error using ==> legend
Handle must be an axes or child of an axes.
Error in ==> tensile_tests_multiple_files at 66
    eval( [ 'legend( ', buildString, ')' ] );
What's wrong!?
buildString = [ '''', int2str( ifile ), '''' ]
for...
buildString = [ buildString, ', ', '''', int2str( icount ), '''' ];
end
