placing datums
placing datums
I need to have a datum that is normal to a plane and passes through the axis of large hole and then through the center of a small hole.
How is that done in wildfire?
Thanks in advance,
SrG
Thanks in advance,
SrG
RE: placing datums
Change the reference type to Parallel in the Datum Plane dialog box.
RE: placing datums
So I can select an axis. But then if I select another hole (in an attempt to get it to pass through the hole) the datum moves and passes through the hole, but it no long passes through my first selection (the axis). How do I get it to retain multiple constraints?
SrG
RE: placing datums
RE: placing datums
I had tried that and it didn't work. It works now. I must have done something wrong.
It's working now,
g
