UNDO a SQL Query
UNDO a SQL Query
Is there any way to undo a query without manually backing up the db before executing the query?
I accidentally performed a date conversion which ruined all of my dates in the db and I need to get those orignal dates back. Any help on retrieving that information is greatly appreciated.
Phreaqo
Phreaqo
RE: UNDO a SQL Query
Is there an old backup you can use?
What was the SQL statement of the original query?
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
