Automatic creation of flange length dimension
I have just loaded SW2006 to test it before moving over to the new version. I do a lot of sheet metal work and one new feature that could save a lot of time is the automatic addition of flange lrngths to the sketch when creating an edge flange. I have created edge flanges in SW2006 and no automatic dimension is added, has anybody seen this work and if so is there a setting to change to enable it.
RE: Automatic creation of flange length dimension
Edge flange can also be controled by the Property Manager.
Please point out where it says this is suppose to be this away in SW06.
Now if you are talking about the drawings, there it adds the some dimensional information about the SM component. See "What's New" or Help for further understanding.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
The dimension you are thinking of is only available when you RMB the Annotations folder after creating the flange.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
This feature is mentioned on page 26 of the what's new highlights booklet that comes with the discs, under edge flange improvements.
That's so you can go back edit the flange profile sketch to meet your needs and add dimensions to it to constrain your flange profile, in which the automatic length then disappears as it's no longer used.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP1.0 on WinXP SP2
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
