Suggest an air flow / velocity meter with RS232
I'm looking for a meter to measure air flow through a 6" PVC pipe. I have some data logging software that communicates with RS232 that I would like to use to capture the data. I'm using google but most of what I find are hand held units, I would like one to mount in the PVC line.
Any suggestions?
Any suggestions?
RE: Suggest an air flow / velocity meter with RS232
Please remember this will measure velocity. If you need mass, you will need a pressure transducer, temperature element and a flow computer to do compensation.
