Radiant tubes in Hot Oil Heaters
Hello...
My name is Farihan.
I want to know what is the material used for the radiant tubes inside the heaters. The tube carries crude oil and operating in a very high temperature.
How do you know the tubes whether in good or bad condition after a long running hours.
How do you monitor the tubes by not shutting down the heaters.
How do you define criticality for the tubes.
I've done IR scanning to the radiant tubes, and the information were very much appreciated for my analysis.
Thank you.
Farihan
