generating a high frequency white noise
Can someone please assist me on how to generate a high frequency (at least up to 1MHz) white noise on hardware? Please direct me to a link where there is a schematic. Any help is appreciated!
RE: generating a high frequency white noise
This should be enough to get you going on a design unless you are not a designer. In which case just buy a noise source as used on noise figure test sets.
If you're having trouble finding a circuit, then Google 'Noise Bridge' because it will contain the noise source as part of the circuit.
