ASTM spec for AISI 304 stainless steel
3
I'm looking for the corresponding ASTM spec for AISI 304 stainless steel (UNS S30400).
RE: ASTM spec for AISI 304 stainless steel
ASTM (www.astm.org) has a huge number of standards which include 304 SS.  E.g., for every form (bar, forgings, plate, pipe, sheet, tubing, wire, etc.).  Below are those with 304 stainless in the title.
A1022-01 Standard Specification for Deformed and Plain STAINLESS Steel Wire and Welded Wire for Concrete Reinforcement
A813/A813M-01(2005) Standard Specification for Single- or Double-Welded Austenitic STAINLESS Steel Pipe
A814/A814M-05 Standard Specification for Cold-Worked Welded Austenitic STAINLESS Steel Pipe
F593-02e2 Standard Specification for STAINLESS Steel Bolts, Hex Cap Screws, and Studs
F594-02 Standard Specification for STAINLESS Steel Nuts
G108-94(2004)e1 Standard Test Method for Electrochemical Reactivation (EPR) for Detecting Sensitization of AISI Type 304 and 304L STAINLESS Steels
If you are only concerned with composition, this is the one:
A959-04 Standard Guide for Specifying Harmonized Standard Grade Compositions for Wrought Stainless Steels
http://www.astm.org/cgi-bin/SoftCart.exe/STORE/filtrexx40.cgi?U+mystore+fisj2787+-L+A959+/usr6/htdocs/astm.org/DATABASE.CART/REDLINE_PAGES/A959.htm
Yes, to need a product form.  ASTM specs aren't alloy specific, each one covers a number of related grades, but they are product form specific.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
The most common ASTM spec for plate, sheet, and strip is ASTM A240.  The most common ASTM spec for bars and shapes is ASTM A276.
  just a quick question, what does the AISI stand for in AISI 304 or other steels?
thanks in advance
American Iron and Steel Institute, which used to maintain a register of carbon and stainless steels.  They no longer do this, so the letters AISI should not be used anymore.
Cory
