conneting concrete slabs
When adding a concrete slab to an exisiting structure, should the new slab be "tied" into the exisiting structure? The thought is that if the slab is "tied" to the exisiting stucture any settlement between the two would not show up at the finished floor as a joint or raised area. The other three sides of the slab would be free to "float".
RE: conneting concrete slabs
www.SlideRuleEra.net
