Compatible to Titanium
Guys,
I want to know if Carbon steel is compatible to weld to Titanium? And if not, any metals than can be welded to titanium and send me technical data to wdatinguinoo@cbi.com
Thanks in advance
lynred
Thanks in advance
lynred
RE: Compatible to Titanium
There have been a few exotic transition joints developed over the years but all are generally considered outside the realm of practicality.
If you can comeback with what you are trying to accomplish there are quite a few people here that have experience with Titanium.
with any Fe based alloy you develop intermetallic compounds.
it will not work.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
This is necessary when the tubes are to be seal welded to the tubesheets and the tubes are also Titanium.
rmw
Forge type welding of carbon steel to titanium like the explosion bonding methods used for cladding or diffusion bonding in vacuum or high pressure argon can be done.
