belts cracking
belts cracking
I have to disc mills of the same model here. But I have some problem with one: the belts are cracking faster and must be replace more often.
The two mills are exaclty the same and grind the same product.
I think maybe a deflection between the two sprockets could cause this problem. What do you guys think?
RE: belts cracking
Worn out sheaves?
Dirt & oil ?
Wrong parts?
Operator abuse?
What is the time span between replacements?
RE: belts cracking
Over tension
RE: belts cracking
RE: belts cracking
So, no over tension, operator abuse, under tension, oil, wrong part, temperature...
but it may be the sheaves, torsional vibration or something else...
RE: belts cracking
RE: belts cracking
If so, Ozone maybe the culprit.
One other possibility is if one belt is exposed to sunlight I read about a case where UV exposure was instrumental in drive belt deterioration.
RE: belts cracking
what's a cog belt, a belt with teeth?
RE: belts cracking
RE: belts cracking
