What's the difference between SPLIT LINE PROJECTION and
What's the difference between SPLIT LINE PROJECTION and PROJECTED CURVE SKETCH ONTO FACE ?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: What's the difference between SPLIT LINE PROJECTION and
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Split line projection takes a sketch, projects it onto a face and then splits the face where the projection of the sketch meets that face such that you can click and select inside the split line it highlights as a separate face all together.
Curve projected to face is there to do pretty much the same thing except it leaves the face in tact and just makes a curve entity on that face.
hope that helps
Jon
