Show Only Mapkey
Show Only Mapkey
Show Only Mapkey
Has anyone created a mapkey to show only a selected part in an Assembly?
To clarify a little, you select a part in an assembly and then select show only. The program then hides all parts except the one selected.
Thanks in advance
Dave
RE: Show Only Mapkey
You can do that with a pause and a brief message to remind you what to select. then when running the mapkey the pause window pops up, select your [part and clcik resume in the pause window.
