Dimensioning a Radius Groove?????
Good afternoon, I have a single part which is a an extruded cylinder, .537 diameter, if it matters. On that cylinder I have a .031 R groove, for a snap ring, which at the bottom of the radius, I need to add a dimension, .502 diameter. So far the only thing I have been able to do is once again lie. This thing will not pick up the bottom of teh radius, or tangent edge, if you like so does anyone have any suggestions on any possiblities on how to do this? I won't say were this was a piece of cake, but I need to show the machinist the dimensions. Thank you in advance for any assistance rendered.
RE: Dimensioning a Radius Groove?????
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
Did you try a section, it should be able to pick up an arc then?
would you mind airing out your dirty laundry.....I'm sure we're all interested in your MCAD background. As you can see in my profile I use SWx & Pro/e 2001 on a daily basis.
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
o
_`\(,_
(_)/ (_)
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP1.0 on WinXP SP2
How about this?
Jason
Still, I did it your way and didn't have any trouble dimensioning it. Have you tried to lock the view focus, I know in the past you couldn't select silhouettes if the view focus wasn't locked on that view.
What version of Solidworks are you using?
Jason
If you have the centre points dimensioned by clicking the arcs, all you have to do now is RMB the dimension, select Properties, then select "Min condition" for both points.
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions FAQ559-1091
Jason
You have to remember this is not UG & should not be used as if it is. SW has its own way of doing things, just like any other CAD package does. Turn on all the shortcuts & menu selections by Tools > Customize > Options and select both Show All buttons. Then experiment with all the ones you haven't seen or used before.
Most members here have transitioned from one package to another. Gildashard has gone from SW to UG, he doesn't complain about it ... too much.
Jason
Jason
Thanks... That's pretty Hamn Dandy!
Windows 2000 Professional / Microsoft Intellimouse Explorer
SolidWorks 2006 SP01.0 / SpaceBall 4000 FLX
Diet Coke with Lime / Dark Chocolate
Lava Lamp
