"RAM" EDM
"RAM" EDM
Can anyone explain the difference between "RAM" EDM and wire EDM? I was told that it is more accurate.
Tunalover
RE: "RAM" EDM
Wire edm is more akin to using a bandsaw. The wire acts as a continous electrode, i.e., the bandsaw blade. The work piece is moved while the wire position remains fixed. The profile of the piece is programed in X-Y coordinates and the piece moved. The wire cuts a narrow cut " the width of the wire" path around the desired profile. Usually very accurately, within 0.0005".
RE: "RAM" EDM
Ram EDM also called spark erosion or die sinking is a machined part, usually copper, graphite or some tungsten alloy that has a current passed through it that erodes its shape into the part being machined. Whilst you can do through holes its main strength is cavities as in mould tools, it is however a fairly slow process if you require any kind of surface finish and the electrodes wear fairly quickly.
Wire erosion cannot do cavities only through holes, however they can be parallel, tapered or even have a different profile top and bottom.
The big advantage with both processes is they can be done on hardened metal.
RE: "RAM" EDM
Spark erosion needs a sacrificial electrode and sometimes a number of them, especially if you have steep angle faces where a large spark gap on the sides takes more cleaning up than on the bottom face as you only travel in the Z-axis.
Wire erosion is programmed so needs no electrode (except the wire itself) and by second cutting or skim cutting tolerances of 0.0002” are easily achievable however you will end up with radii in the corners of about 0.006”.
So basically spark erosion is an alternative to CNC milling cavities, especially where corners are needed at depth.
Wire erosion is more accurate, but can only do through holes or profiles, not cavities, but also consider laser, plasma, or water jet cutting.
