Excel VBA Subscript/Superscript Macro
All,
I wrote this VB code for automatically subscripting/superscripting text. I find it very cumbersome to subscript and superscript text in excel. The following macro requires that you put brackets [] around anything you want subscripted and tildes {} around anything you want superscripted.
An example would be:
D[col] + x{2} + C[1] + Y[base]
Hope this helps.
CODE
Sub Super_Sub()
Dim NumSub
Dim NumSuper
Dim SubL
Dim SubR
Dim SuperL
Dim SuperR
Dim CheckSub
Dim CounterSub
Dim CheckSuper
Dim CounterSuper
Dim Cell
CheckSub = True
CounterSub = 0
CheckSuper = True
CounterSuper = 0
Cell = ActiveCell
NumSub = Len(Cell) - Len(Application.WorksheetFunction.Substitute(Cell, "[", ""))
NumSuper = Len(Cell) - Len(Application.WorksheetFunction.Substitute(Cell, "{", ""))
Do
Do While CounterSub <= 1000
SubL = Application.WorksheetFunction.Find("[", ActiveCell, 1)
SubR = Application.WorksheetFunction.Find("]", ActiveCell, 1)
ActiveCell.Characters(SubL, 1).Delete
ActiveCell.Characters(SubR - 1, 1).Delete
ActiveCell.Characters(SubL, SubR - SubL - 1).Font.Subscript = True
CounterSub = CounterSub + 1
If CounterSub = NumSub Then
CheckSub = False
Exit Do
End If
Loop
Loop Until CheckSub = False
Do
Do While CounterSuper <= 1000
SuperL = Application.WorksheetFunction.Find("{", ActiveCell, 1)
SuperR = Application.WorksheetFunction.Find("}", ActiveCell, 1)
ActiveCell.Characters(SuperL, 1).Delete
ActiveCell.Characters(SuperR - 1, 1).Delete
ActiveCell.Characters(SuperL, SuperR - SuperL - 1).Font.Superscript = True
CounterSuper = CounterSuper + 1
If CounterSuper = NumSuper Then
CheckSuper = False
Exit Do
End If
Loop
Loop Until CheckSuper = False
End Sub
Dim NumSub
Dim NumSuper
Dim SubL
Dim SubR
Dim SuperL
Dim SuperR
Dim CheckSub
Dim CounterSub
Dim CheckSuper
Dim CounterSuper
Dim Cell
CheckSub = True
CounterSub = 0
CheckSuper = True
CounterSuper = 0
Cell = ActiveCell
Do
CheckSub = False
Exit Do
End If
Loop
Do
CheckSuper = False
Exit Do
End If
Loop
End Sub
Hope this helps.
RE: Excel VBA Subscript/Superscript Macro
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Steam Engine enthusiasts: www.essexsteam.co.uk
