2005 Import Diagnosis
According to help: "The Import Diagnosis PropertyManager appears when you import a file, right-click the imported body, and select Diagnosis. "
I do not get "diagnosis" in the menu. I've tried right-clicking the body in the graphics window & the feature tree. No luck.
Is this "diagnosis" option time sensitive (only available before you save the part)?
RE: 2005 Import Diagnosis
avlis,
Do you have any features after the import feature?  If so, the diagnosis option goes away, even if you rollback to the imported feature.
You can use the check tool, however.
Dave Gowans
If you added anything to the Feature manager "plane, feature, anything you will not get that option.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Ok. Yes, someone added features after the body before fixing the import error.
