Missing "File" "Window" and "Help"
I'm hoping that someone know how to fix this...
Somehow, I have lost my "File," "Window," and "Help" pulldowns from the upper-most standard toolbar ONLY in my assembly files. Very irritating. The last thing I remember doing is turning on the toolbox add-in.
I tried unchecking and rechecking it, closing & reopening SW. Does anyone happen to know how to fix this?????
RE: Missing "File" "Window" and "Help"
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions FAQ559-1091
Close SW
1) Start "Run"
2) Type "Regedit" (without quotes)
3) HKEY_CURRENT_USER\Software\Solidworks\Solidworks [version]\Menu Customizations
4) RMB "Menu Customizations"
5) Rename "Menu Customizations" with your initals e.g. "Menu Customizations_SB"
6) Minimize window
7) Restart SW
8) Open up a new file and test
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Jeff Mowry
One minutes you are hacking the registry, next time you restart, your system is dead... what a wonderful thing!
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Scott ... Should the renamed key be deleted after the test is proved OK?
Best Regards,
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
