ethernet to RS 485 interface
I am trying to source such interface for HV (330 kV) control room.
any references you will recommand ?
thanks.
thanks.
RE: ethernet to RS 485 interface
www.precidia.com
Cyclades TS-100 - This is a Linux based device, DIN rail mountable, very configurable, but requires a little more time to figure out.
www.cyclades.com
We use both in automation control, both are reliable.
If you want something a little easier to configure quickly, I would go with the Precidia. They are distributed through BWI, www.bwi.com
