Pause a process
Pause a process
Hello friends,
I have a problem pausing a process from GUI interface in MATLAB.
So here are the details of my problem
I was trying to plot XY-graph.
So for that i made three buttons in the GUI
say
Plots
Pause ON
Pause OFF
when I press <Plots button> it plots from 1:1000 on x-axis and rand(1000,1) numbers on Y-axis
so I do this in different figure other than using GUI-axes property (as I need it that way)
plotting works fine,
but when I want to pause the plotting in between I cant do it
here is my code, please give some suggestions
plotss.m
function varargout = plotss(varargin)
<all default GUI stuff>
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
plot_example
% --- Executes on button press in pushbutton2.
function pushbutton2_Callback(hObject, eventdata, handles)
pause on
% --- Executes on button press in pushbutton3.
function pushbutton3_Callback(hObject, eventdata, handles)
pause off
plot_example.m
function plot_example
x=[1:1000];
y=rand(1000,1);
z=rand(1000,1);
a=[];
b=[];
c=[];
figure(2)
for i = 1:size(x,2)
a=[a;x(i)];
b=[b;y(i)];
c=[c;z(i)];
plotting(a,b,'r')
plotting(a,c,'b')
end
%plot(x,y);
%set(handles.ax,h);
function plotting(xx,yy,colors)
hold on
plot(xx,yy,colors)
drawnow
say
Plots
Pause ON
Pause OFF
plotss.m
plot_example
pause on
pause off
plot_example.m
x=[1:1000];
y=rand(1000,1);
z=rand(1000,1);
a=[];
b=[];
c=[];
figure(2)
for i = 1:size(x,2)
a=[a;x(i)];
b=[b;y(i)];
c=[c;z(i)];
plotting(a,b,'r')
plotting(a,c,'b')
end
%plot(x,y);
%set(handles.ax,h);
hold on
plot(xx,yy,colors)
drawnow
RE: Pause a process
To pause with pause you want pause(n) or pause(inf)
or possibly waitforbuttonpress.
or probably better in this case uiwait and iuresume, which respect the gui a bit more.
I suggest :
global fighandle
uiwait(fighandle)
global fighandle
uiresume(fighandle)
in conjuction with passing the figure handle as a global from the plot_example function.
And also keeping track of the axes in the external figure, so that the plotting doesn't jump to the active object (being the form), when you make it active by clicking on it.
x=[1:1000];
y=rand(1000,1);
z=rand(1000,1);
a=[];
b=[];
c=[];
figure(2)
global fighandle;
fighandle = gcf;
axhandle = gca;
for i = 1:size(x,2)
a=[a;x(i)];
b=[b;y(i)];
c=[c;z(i)];
plotting(a,b,'r',axhandle)
plotting(a,c,'b',axhandle)
end
function plotting(xx,yy,colors,axhandle)
hold on (axhandle)
plot(axhandle,xx,yy,colors)
drawnow
RE: Pause a process
It works thx for your help.
