titanium grade for seawater relief valve
I'm designing a small (>.625") diameter relief valve for use in a salt water environment and need it to retain as much mechanical strength and surface finish (it will be a sealing surface via o-rings) as possible. Recommendations for a specific titanium or other material (or coatings).
RE: titanium grade for seawater relief valve
Is this cold seawater? If so a CP or low alloy grade will work.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
thanks for the help folks
