17-4 heats -Let me count the ways
Now I see HH1150 or H1150+1150 from BearCraft.  Apparently this is two times through H1150 process heat treat.  BearCraft publishes a separate set of mechanicals that go with it.  Also now I am seeing published mechanical properties for Condition A solution annealed state, where before Carpenter and others refused to publish condition A mechanicals.  Also see that ductility for condition A can be all over the map.  How about the material community bringing some order to this chaos?
For years I advised my shop not to use 17-4 at condition A for load bearing because of unpublished mechanicals.  Now I am having second thoughts.  What is the consensus of this august body?
RE: 17-4 heats -Let me count the ways
Based on many many years of using 17/4 for mechanical components and many many discussions with the ARMCO and Carpenter technical people in my opinion you are correct in not using 17/4 in Cond. A.
    H900        Only for thrust or compression applications
    H1050       Highest strength level in tension due SCC
    H1100       Some shafts and pressure containing components
    H1150 x 2  The toughest applications
    H1150-M    Recover property values due to inservice    hardening
We used several other treatments due to forming considerations.
I have never seen consistent physicals from 17/4 no matter the source.  We got by just looking at a the minimum valves in the area of interest.  We were able to do this as we were an industrial arena and normally weight and size weren’t a factor.
Just to add. it is easier to machine in the heat treated condition than the A condition.
It is easier to cold work it in the over aged condition than in 'A' also.  We anneal, over age, cold work, reanneal, and final age.
Allegheny Ludlum publishes 'A' values, but I wouldn't use the material in that condition.
If you want it soft use the 1400/1150 over aging.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
