Suppressed mates across Assembly Configurations
I have a motor assembly with about 10 configurations varying length, width, height etc etc. I recently decided that I would like to put some bearings into the assembly. The bearing would be the same across all configurations. I applied 3 mates to the bearing (concentric, coincident and parallel). However, when I move to another configuration my bearing is free to float around the screen. When I check I find that the 3 mates I assigned in the previous configuration are now 'suppressed'. The solution is to unsuppress all 3 mates. However, this is a real slow pain. Is there anyway I can specify that I want the bearing mated the same in all configurations?
RE: Suppressed mates across Assembly Configurations
Flores
SW 2006 SP1.0
Maybe an API could be written to iterate through & change multiple config properties advanced options.
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions FAQ559-1091
