snow load on RTU's
snow load on RTU's
With RTU's is it too conservative to apply the basic roof snow load to the top of them, or can you assume that wind removes some or all of the snow? I haven't found anything that addresses this. It seems to me that if you have a large unit up on a platform, you should be applying the full snow load to it. That is the case I currently checking. I think a large unit on a platform creates a "shadow" that prevents snow from getting under it, so a snow load should be applied to the top. The question is, is it reasonable to assume that the wind will prevent a full snow load from developing on top of the unit.
RE: snow load on RTU's
