Chdir returns error
Chdir returns error
Chdir returns error
I have the following scenario. A shell script writes the name of the directory (Example: 10-24-05) into a text file progress.txt. I have a VBA Macro reading this file to pick up the name of the directory to change to. I am using the following code to do this:
Open "I:\tests\progress.txt" For Input As #20
Line Input #20, ResultsDate
Close #20
DirPath = "K:\current\" + ResultsDate
ChDir DirPath
When I run this, I see an error saying the path was not found. But incase I assign ResultsDate = "10-24-05" instead of reading it from a file, that seems to work fine. Can anyone tell me what I might be doing wrong ?
Thanks !
RE: Chdir returns error
A couple of suggestions to try:
  • Change the line
    CODE
    to
    CODE
    DirPath = "K:\current\" & ResultsDate
    & is the proper string concatenation operator in VBA
  • Inspect ResultsDate (while single-stepping through the code) for extra spaces.  If that's the case, you can remove using
    CODE
    Trim(ResultsDate)
Hope this helps,
Mike
There are a number of characters which cannot be used in the name of a directory or file.  You might want to verify that the date, as read from the progress.txt file, does not contain any illegal characters.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
