Beam Stiffener Material
I am trying to reinforce an aluminum member with steel to control deflection. I do not have enough room to add enough steel to meet the deflection criteria. Does anyone now of a higher modulus material that is readily available in barstock? I have looked into tungsten wihout much luck. Thanks for your help.
RE: Beam Stiffener Material
http://www.matweb.com/search/GetProperty.asp
(Use MatWeb, Use a property search, Metals, modulus >250)
Or as I often say to people sure I can spec. unobtainium, just tell me where to buy it.
You will have to get your stiffness through geometry.
It won't be cheap, but less money and weight than W.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
