Circuitmaker tip needed...
Now that Circuitmaker is no longer sold or supported I need to know how to make it do something. (Figures) Does anyone out there have, own or use this anymore? If so, I need to simulate a simple circuit like a cap charging through a resistor (RC Time Const) I can simulate the CKT okay but I want to be able to make the supply NOT turn on until a few mS AFTER I start the simulation so i can clearly see the voltage plot on the cap at zero volts so I can clearly see the ramp as it happens from zero to max. Any ideas?
Thanks in advance,
Dave
Thanks in advance,
Dave
RE: Circuitmaker tip needed...
manually or you can write a simple 5-10 line BASIC
program. Using simulation would be like hunting
for ducks with ICBM-s.
<nbucska@pcperipherals DOT com> subj: eng-tips
read FAQ240-1032
TTFN
Dave
