capacity of a beam supporting plank
When designing a steel beam to support hollow core plank floor, can this beam be designed as composite, or considering only 1" width is available at the stud location, should the beam be designed as non-composite.
RE: capacity of a beam supporting plank
DaveAtkins
I would contact the manufacturer for advice on specific planks.
