Import/Export Drawing Properties
I think I am using the wrong key words in the help and searching on here.
I have one drawing file out of 15 that has all the correct title block information filled out with custom properties.
I have 14 other drawings that I need the exact same thing, is there any way to export out the props. and re populate the other drawings with them.
Don't need to do all the drawings at once, just one at a time. Thanks in advance once again.
They are all seperate drawing files, of course if I waited to do the drawings once I got all the information I would be late.
RE: Import/Export Drawing Properties
The properties should be assigned to the parts as you create them & the drawings should be populated from the parts properties.
Or have I misinterpreted your question?
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions FAQ559-1091
Also, "PropertyEditorSpec" at ht
Will try your way to wg
What I do is create parts and drawing templates for a project, with all the properties I need assigned to these and saved as templates (dot files). I put a sample part in the drawing as a front view and save it. Of course, the part info gets stripped out, but the view remains. When I create the actual parts and am ready to do drawings, I assign model Front view to the one my drawing will use as the primary view, and then do projected views from that.
Once a project is done I can trash the templates. Drawing formats is a separate issue . . .
Hardie "Crashj" Johnson
I hope I have explained this enough. If you have problems please re-post and I will explain further.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2006 SP0.0
Thanks.
glad I could help out.
Best Regards,
Jon
