Edmonton Area Frost Line
I am wondering if anyone out there knows, generally, what the depth of the frost line is in the Edmonton area.
I am assuming that I can bury a raw water pipeline 8 feet below ground, and the water in the line will not freeze.
RE: Edmonton Area Frost Line
I suspect frost penetration varies widely dependent on many factors (while I don't know about the accuracy or dependability of same for design purposes, you may want to look e.g. at Figure 1 at the site http://irc.nrc-cnrc.gc.ca/pubs/cbd/cbd026_e.html and e.g. also say th einformation including a freeze index map like on pg 11 of site  http://www.owenscorning.com/worldwide/admin/tempupload/pdf.3-74495-199_HighDensity_E.pdf).
Hopefully you will get perhaps better experience-type response from area.
In a similar thread some time back, someone suggested asking local undertakers. They'll know.
     "...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail."
              Wm. Phelps Eno, ca. 1928
