Typical Cut Speed for 0.55mm Stainless Steel
Does Anyone know what are typical cut speeds on simple shaped part for a good quality dross free cut on 0.55mm 304 stainless steel (without plastic flim) & using nitrogen.
The best we can get is 13-14 metres per minute,15 has a fine dross. Our nearest factory parameter files for double this thickness have cut speeds of 18 metres per minute.
Is this unrealistic ?
Steve
Steve
RE: Typical Cut Speed for 0.55mm Stainless Steel
I never worked with anything that would cut 1mm 304 at 700 ipm, but I heard of systems that would.
What kind of system do you have?
Have you discussed this with the reps?
I'm assuming that you went through some kind of factory-recognized training?
Jay Maechtlen
http://home.covad.net/~jmaechtlen/
I have tried:Focus point: -2 and max gas pressure: 8bar (nitrogen). it looks better but still dross present.
Could somebody write some optimal condition to cut?
