FATIGUE-APPEARANCE-TRANSITION TEMPERATURE (FATT)
1) Can someone explain how to calculate FATT for a given metal ?
2) Is it a link with a Charpy-V Transition Curve Temperature ? Please explain ...
3) Any reference documentation about FATT will be appreciated .
Sincerely,
A_Tsampalas
RE: FATIGUE-APPEARANCE-TRANSITION TEMPERATURE (FATT)
You are referring to the fracture appearance transition temperature (FATT). This is a value that is selected from Charpy impact testing of steels that exhibit a ductile to brittle transition temperature.
Your question is too board for this forum. There are various web sites that can explain further;
http://www.key-to-steel.com/Articles.htm
Scroll to the article of interest regarding brittle fracture.
J.F.Harvey's "Pressure Component Construction" has a good info [sections 5.22-5.26 in 1980 edition] on fracture, Charpy's etc.
also:
J.A.Collins "Failure of Materials in Mechanical Design" par 3.7
Ashby & Jones "Engrg Mat'ls" p.150
"L.R.Hurst "Brittle Fracture of a Brick-lined P.V." Mat'l Perf. March 86 pp.24-26
Dear MM Metengr  and Arto,
Thanks for your answers.
I know how to obtain  CV ductile-to-brittle transition temperature curves .
I have never used FATT .
In found documentation, the writer suggests :
" After CV specimens were tested...From the fractured surfaces of the specimens, the FRACTURE-APPEARANCE-TRANSITION TEMPERATURE at 50 % cleavage (FATT 50) can be determined ".
As I am not acquainted with FATT, the subject (previous affirmation) seems unclear .
Can you please clarify ?
Sincerely,
A_Tsampalas
I believe that you may find illustrations of % cleavage of CVN specimens in ASTM A20 or A370.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
The FATT is a value based on a visual percentage of flat (cleavage) fracture on the broken impact specimen. Typically, percent flat fracture is a variable that is plotted on a Charpy impact energy graph as a function of test temperature. At the temperature where 50% of the fracture surface is flat and the remainder is shear, this is the FATT @50%.
