API STD 560
API STD 560
WHAT IS THE PRESSURE TEST VALUE ACC. TO LAST EDITION of ABOVE MENTIONED CODE? 1.5px(Sa/St) or 1.3p...
Many thanks for answer.
RE: API STD 560
RE: API STD 560
Which test pressures ? which section of this API?
In principle, tank will be tested with water in:
1/- incorrded condition.
2/ Whith obviously water , which has s specif gravity higher than most of the oils, products..
3/- Design stress for hydrotest is a bit higher than for design with real fluid.
I think your 1.3 x Stress ratio)x design pressure is for new ASME VIII - div.1 vessels.
We will hear from the others!!!
RE: API STD 560
RE: API STD 560
