Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...You have made an incredible site which is truly a great help to me in solving problems. A tip of my hat to you!..."
Geography
justbuildit (Civil/Environmental)
26 Oct 05 0:20
I am trying to estimate how many tons of riprap per neat cubic yard of placement.  I am thinking along these lines:
1) Determine riprap density from source...assume 155 lbs/ft3 in this case.  That's about 2.09 tons/cy of 'rock'
2) Now the part I need someones experience on is how much void to factor in.  If voids account for 33% of the total volume then this reduces to 1.5 tons per 'neat' cy.  I realize this can vary, but what we have to use something.  I think the void ratio would also vary by what size of riprap is being placed. What void ratio would you use for the
a) 1/4 ton riprap
b) 1 ton riprap
c) 3 ton riprap
d) 6 ton riprap
3) I would also use this information to determine the quantity of concrete used to fill the voids if placing concreted riprap.
Thanks for your help
LHA (Civil/Environmental)
19 Nov 05 13:32
I use 165 lb/cf, 155 is fine.
The void ratio depends on the shape of the object and adjacent objects, not the size of them, provided they are similar...round 6" stone would have the same proportion of space between them as round 12", etc.
For irregular (quarried, ripped or blasted) stone, I use 40% void space, and that is so typically used that I have never bothered to reference a source.  I've seen 35% frequently also, so 33% should be conserative enough for tonnage, while not underestimating the concrete.
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
cvg (Civil/Environmental)
28 Nov 05 10:58
A common spec requirement is for the stone to have a minimum specific gravity.
"In addition to the requirements of section 703.1, stone for riprap shall have a minimum apparent specific gravity of 2.4 per ASTM C-127"
Close Box
Join Eng-Tips® Today!
Join Us             Close
