Cost for Multiphase pump
Hi everybody,
I would like to know the roughly budgetory cost for the pump that can handle continuous work of gas 75 MMscfd, Oil 10000 bbld and water 10,000 bbld (GLR=.75) TDP 300 and Discharge P= 850 psi T=100 F API=26 supply by 46o volt 6o hz 3 phase.  I know that it 's must be very complicated and expensive one but it might cheaper than another process platform (offshore)
Thank you in advance
