Hole Table anchor point
While trying to use the hole table feature, I can't seem to get the table to attach to the anchor point.
Round#1: While inserting the table, I realized that I hadn't set the anchor point, so I ended the function and went and set the anchor point.
Round#2: Having set the anchor point, I went to insert the table again, but still could not attach to the anchor point.
Round#3: I went through the system and document properties to see if I had missed anything, nothing seemed to be out of the obvious.
The check box still seems to be grayed out for some reason.
Any suggestions?
Any suggestions?
Christopher Zona - Senior CAD Designer
Litens Automotive Partnership
Concord, Ontario
RE: Hole Table anchor point
Concord, Ontario
I started a template from scratch which had the table property controls and all is well now.
Concord, Ontario
I think you must have spent too much time in Woodbridge.
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions FAQ559-1091
Concord, Ontario
