storage-discharge relationship
I am using HEC HMS to do river reach routing.  I have an existing bridge and several proposed models as well.  I am trying to compare the existing outflow at 100 year storm (and others) to the proposed outflow at the 100 year storm.  I am using Modified Puls routing.  I am trying to find out if I can use the rating curve points from HEC RAS as my elevation-flow values to use in the HEC HMS model?  If so, from which cross section do I use the rating curve?  Upstream of the bridge?, just inside the upstream face?, just inside the downstream face?
RE: storage-discharge relationship
It was my experience that HEC-RAS is much more conservative performing storage-discharge calculations than was software designed for the purpose (specifically, Hydraflow Hydrographs 2002).
Our justification for using Hydraflow's output in preference to HEC-RAS's for culverts with pressure flow was that HEC-RAS's 1-dimensional calculations were not as accurate in this particular instance as the 3-dimensional volume calculation used by Hydraflow.
Essentially, we modeled small culverts under pressure as normal detention basins, while we retained HEC-RAS's output for bridges with large flows.  I should point out, however, that we were designing the culverts and did not want to have any weir flow as the culvert was under a road.   When we modeled a bridge, however, we stuck with HEC-RAS as the component of pressure flow was minimal compared to the flow overtopping the abuttments.  Also, HEC-RAS's input for bridges is more detailed than that for culverts.
Thanks, but that doesn't really answer my question.  Maybe I didn't word it well.  I have a bridge model in HEC RAS.  I have several different profiles in my steady flow file.  After I run the computations, I end up with a rating curve that shows a relationship between elevation and flow at different stations in my channel.  Now--think of HEC HMS or even HEC1.  I need a stage-volume-elevation relationship to do routing.  I have my stage-volume relationship from the terrain model and the spreadsheet calculations for accumulated storage.  What I am asking is:  Is the rating curve I received in HEC RAS an accurate relationship between flow and elevation so that I could take points from that curve and use them as input in my HEC HMS routing model?  And if so, at which station's rating curve do I take the points?  If not, what's the best way to find that relationship?
yes - if your HECRAS model is done accurately...
it would be hard to find another analytical method that can beat HECRAS for bridge hydraulics.
I've seen the approach you say used to develop a Stage-Volume-Discharge table (F-table) for HSPF modeling.  I think accuracy is going to be more tied to the spacing & number of HEC-RAS x-sects than the actual error in the numerical modeling method, so long as you are using subcritical flow when appropriate in the HEC-RAS.
IMO this is a good approach to use when measured flows are not available to correlate stage to discharge, especially if the HEC-RAS is set up carefully.  If measured flows are available, be sure to use them to validate the HEC-RAS or to directly develop the relationship in HEC-HMS.
So, I could use this relationship instead of using Manning's equation for open channel flow, the orifice equation, and the weir equation?  I hope so, because for a natural channel bottom, those equations get real messy in terms of wetted perimeter and area.  It would be way too time consuming to establish a elevation-flow relationship that way.
No one ever said if it mattered about which station's rating curve I should use.  At and around the bridge station, the curve is a little different.  Which station would accurately represent the relationship I need for routing in HEC HMS?
I would recommend HECRAS over your manual method which probably does not account for backwater, contraction or expansion losses, overbank flow or variable n-values
