Ansys acoustic analysis - I need Help!
Hi Everyone,
I'm trying to run some acoustic cases on Ansys using the element FLUID29. I'm having trouble to extract the velocity nodal result in a fluid element after running a harmonic analysis. It seems that only nodal results for pressure are avaliable, although the specs of this element (FLUID29) say that the nodal results for displacement are avaliable. Up to now I can only extract displacement (or velocities) in the fluid structure interface but not on a fluid element itself which is limited to pressure results.
I would greatly appreciate if someone could give me some ligth on this topic.
Thanks in advance.
RE: Ansys acoustic analysis - I need Help!
the nodal velocities are available, not displacements
Frank Exius
IFE Deutschland
www.ife-ansys.de
Telefon ++49\2642\980409
Germany
Dienstleistung in ANSYS
FEM Berechnung Simulation
Digital/virtual Prototyping
displacements are available at FSI structural elements
to get the velocities in the fluid, you might need use appropriate label NMISC on PLSOL, as given in element description in doc's
