earth wire rating
earth wire rating
i have a machine which consists of a 500mA fuse and i am using 0.5mm 11 amp rated earth wire. the boys at work tell me it should be 4mm but i thought thats ridiculous. is 0.5mm enough?
RE: earth wire rating
John
4mm makes no sense.. that is about 6AWG or 37Amp rating.
Depending on what you are doing industrial wiring often has limits like "nothing less than 16AWG" This is for mechanical strength and to allow any electrician to have the required tools at hand.
One day my ship will come in.
But with my luck, I'll be at the airport!
Teach me to deal with metric nonsense.
the fuse would blow well before 11 amps. i am going to upgrade the wire to maybe a 14 amp 0.75mm wire.
would i require earth ratings exceeding this and why?
Surely the earth only has to be rated enough to blow the inlet fuse?
