Phase Shift Circuit
Phase Shift Circuit
Phase Shift Circuit
I would like to know if there is any way of applying a phase shift to a 50Hz AC voltage.
I know that it is done on circuit board using op-amps, but is there any way of doing this at a high power level, say phase-shifting the 220V single phase AC voltage to a 20kVA load.
RE: Phase Shift Circuit
a phase shift transformer?
Is there any way to use power electronics to do this?
Or is a phase-shift transformer the only way to do it?!
Yes, there is a way to phase shift and input power source. There are at least the following options:
        - Phase shifting transformer.
        - Rotary converter.
        - Static converter.
NOTE: Three-phase transformer connected delta-wye provides a natural fix phase shift of 30 degrees. Phase shifting transformer is available for high voltage applications. I am not sure if at LV there are commercially available cost effective options. Check the enclose link for reference.
http://www.50hz.com/Solid/3ph/6050/120KSS35060.htm
http://www.50hz.com/Rotary/625IND5060QV.htm
Thank you for your help.
I have now decided to avoid using power electronics, so I guess that a phase shifting transformer is the only way to proceed!
