Header flat plate end closure
I need to figure some flate end closures for a pipe header and do not have access to ASME books or for that matter any pressure vessel references. I have searched the net for the methods used and have had no luck. Can you please point me to some data on this subject or recommend a god book that I can order which will cover general pressure vessel and pipe capculations.
Thanks, Ken
Thanks, Ken
TXiceman
www.rae-corp.com
RE: Header flat plate end closure
and for the piping you'll need to find something w/ Section 1 PP Power Piping for the header plates.
Brian
Have you considered a simple slip-on flange with a blind for an end closure ?
How about a simple cap ?
If you are thinking of slipping a flat plate up into a pipe and fillet welding from the outside, this type of construction will not meet the ASME-VII requirements.
My opinion only...
-MJC
If the work needs to meet any kind of code, or poses any kind of hazard if it fails, I'd recommend buying the proper codes or consulting someone that has them. The Roark book, for example, will let you calculate stress, but won't tell you what the stress should be.
Thanks for the lead to the handbook, Wabbitt.
Ken
TXiceman
www.rae-corp.com
