IEC vs. UL/NEMA
IEC vs. UL/NEMA
Anyone know the difference and/or the pros and cons of uisng IEC rated equipment versus UL/NEMA rated equipment?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: IEC vs. UL/NEMA
In the US, all equipment needs a UL label, regardless of whether it's built to IEC or NEMA standards.
If everything else seems equal, check the physical size and weight.
RE: IEC vs. UL/NEMA
If so, here's a quick comparison and (I believe)is true for all major brands such as AB, Square D, GE, etc.:
NEMA components are more rugged, field repairable, larger, last longer, more versatile, and generally are more costly.
IEC components can do the job well, are smaller, and cheaper. That seems to be the deciding factor anymore.
I prefer using NEMA whenever possible.
