problem wiht deformation
Ok today I analyzed a cylinder and on one end there are holes where that end is fixed with bolts and the other end is being pulled. I added all the constrants and loads ...well when I ran the analysis everything works fine no errors or warnings. BUT when i go back to the modeler and press F5 or the view>>select menus i can't see the deformation or anything. When you press F5 in NEiNastran that menu that pops up ...it doesnt let me select any Deformed Style or Contour Style (likes its all shaded oput) options only the Model Style. I'm pretty sure there's deformation? Can anyone help me im lost here??
