BOUNDARY BLEND PROBLEM
Another question....
I have modeled a fuselage/wing combination in proe. the wing and tail are solid parts and the fuse was created with boundary blends. Is there a way to make the fuse a solid based on these boundary blends. Ultimately, I am trying to make a stereolyth model for windtunnel testing.
Thanks again guys,
Chris
Thanks again guys,
Chris
RE: BOUNDARY BLEND PROBLEM
Steve
http://www.sprdesign.com
http://www.3dlogix.com
Sometimes to make solid and trying to merge all the surfaces to make it leak proof can be challenging. You may half to create some addtional surfaces and merge them.
