Simple convert from decimal fraction into normal fraction!?
Simple action but i dont catch on to this...
RE: Simple convert from decimal fraction into normal fraction!?
If you click on a specific result, then select the menu item for Format|Result and select Fraction.
If you select a blank spot on the sheet, and do the above, all results will be fractional
TTFN
after evaluating...thx :)
